b00stJunkie »
https://forums.nicoclub.com/b00stjunkie-u54857.html
Sun Feb 25, 2007 6:08 pm
Ok so i followed the wiring write up, using the 2 rb 20 plugs (6 and 8 wire) wired the purple/white wire into the white wire on the fuse box. wired the fuel pump. grounded the starter to the frame. Now when i go to crank the car, when i turn to key to prime the fuel pump, it only primes sometimes, then the temp gauge shoots past hot, when i turn the key to crank it, it just clicks and everything dies. if i hold the key then that lil blue box (i believe its from the headlights) makes a rattling noise and then when i let off the ignition, the egi relay in the fuse box (middle one) clicks. The other thing is if i try and turn my head lights on w/ just the key on accessories, sometimes they come up nice and bright, sometimes everything dies. What in the world is going on, i checked all my grounds (that i know of) and they are all grounded. =[ what now?
