rb20 will not start! help
firstwizardshawn
Car: 1990 NISSAN 240SX
i have wired it to the spec i got from here and all i get is click click click. and that is not even from the starter. it will not run over at all. brand new battery engine is not locked up. i am at a point where i can not figure it out. what might i be missing. i get a solid red light on the ecu. please i need help from the rb Gods to fix this. thanks in advance.
firstwizardshawn
I REALLY NEED HELP. PLEASE!
jdmser
Car: duh
I would check your battery connections and then your starter connections. Make sure the battery connections are clean and shinny before you put them back on.
Sil240
Car: Nissan S13 "The One Cam Wonder"
Is the clicking coming from the two green relays on the Pass side, under the dash?
For the Lower harness your using the stock KA harness right?
Over by the ecu is a white plug with a Orange and I think white stripe, that should be your Ignition start signal, make sure that one is hooked up.
Cpt_Impossible
Car: G35 6MT
If one of the plugs by the battery isnt hooked up it wont allow starter to start either. Check that big plug that has two plugs going into it.
firstwizardshawn
THE CLICK IS COMMING FROM THE DRIVERS SIDE FUSE BOX BY THE INTERCOOLER PIPING. AND I DO HAVE LIKE AN ORANGE COLOR WIRE THAT IS NOT CONNECTED TO ANYTHING. IF IT IS THE IGNITION WIRE WHERE WOULD IGO ON THE WIRING TO THE ENGINE?
Sil240
firstwizardshawn wrote:THE CLICK IS COMMING FROM THE DRIVERS SIDE FUSE BOX BY THE INTERCOOLER PIPING. AND I DO HAVE LIKE AN ORANGE COLOR WIRE THAT IS NOT CONNECTED TO ANYTHING. IF IT IS THE IGNITION WIRE WHERE WOULD IGO ON THE WIRING TO THE ENGINE?
Yeah bro that orange wire on the white plug near the ecu in the pass side kick panel is the Ignition start signal.Check the FSM to see which Pin that it goes to.I don't remember which one it goes to.
Hopefully thats the prob.
