Cpt_Impossible »
https://forums.nicoclub.com/cpt-impossible-u43114.html
Mon Nov 27, 2006 2:51 pm
I was just curious what pressure levels other RB20's are making without a boost controller.Mine is running .76bar in Seattle which is just above sea level with 3" d/p, 3" cat delete, N1 Catback and a 25"x11"x3" FMIC (same sided) which I think would have some pressure drop.
I'm just worried about grenading the stock turbo. 11psi at the intake manifold means that I am really probably almost 12psi. I have a Joe P phantom boost controller waiting to go in, but Im hesitant to raise the boost any. It seems most of our turbos go out when pushing more than 12psi consistently. I think it may still be worth it to put it in and leave the boost alone just for the spool benefits of the ball spring type controller.
What do you guys think? Is 11psi normal without a boost controller?
