ddtrav2 »
https://forums.nicoclub.com/ddtrav2-u172367.html
Tue Apr 24, 2012 8:06 pm
Yeah. I know the Variable Valve Thing for the rb25det is not on the rb20. So here is what I concluded. I think the only problem is that the rb25det has sub harness for injectors and I think the harness I got does not come with the sub harness for the injectors. I also think I saw a ignitor. So I think getting a rb25 Injector sub harness and then changing the plugs to the rb20 injector plugs then switching pin 114 and 116 at the ecu. The ecu pinout will still be the same. You are right there are some other sensors but the rb20 ecu does not use these other sensors and the pinout is blank. So basically the other stuff won't matter to the ecu or it won't even be able to read or use the extra sensor info. Like A/T Input DT3 and 4 For example.
