Liquidus »
https://forums.nicoclub.com/liquidus-u11556.html
Tue Sep 27, 2011 10:32 pm
So, I noticed today a label on my wiring harness that says Rb25S13, which makes me think the previous owner got a pre-made wiring harness. Problem is, this is an RB20, not an RB25. Can anyone tell me what the differences are?
Looking at the ECU pinouts, it looks like pins 112 and 114 (injectors 4 and 6) should be switched, and that pin 57 on the RB20 is throttle valve switch power supply vs Rb25 exhaust temperature sensor signal.
There are other things that I'm not sure on, for instance on the wiring harness just above the injectors there is a resistor plugged in. Could that be something that I shouldn't have.
Anyway, I inherited this car as a project. It's running lean and I'm trying to get it running right. Thinking this may have something to do with it.
Thanks,
Rob
