tylerdunigan »
https://forums.nicoclub.com/tylerdunigan-u86935.html
Mon Feb 28, 2011 1:30 pm
I pulled into the garage Thursday night, with everything running great. Thursday morning, I go out to go to work, and my car just turns over, but never acts like it wants to start. I can hear the fuel pump come on, and I can pinch the fuel line after the filter, and feel the fuel rush in when the key is turned. I've pulled out one of the coilpacks, put a plug in it, and could see it arcing over to the valve cover. I've completely charged the battery, checked the grounds, looked for disconnected plugs, changed fuses/relays, changed the MAF, replaced a dead injector, and fixed 2 vacuum leaks that I found. I'm installing a fuel pressure gauge as soon as I get home from work tonight, to see if the fuel pump is just weak. I may be wrong, but I don't see how the CAS or the ignitor chip could be bad, since I am getting spark and fuel. I tested the ECU, and I am getting code 55 from it, so that should be fine as well. I've spent roughly 18 hours over the weekend, pulling stuff off and checking it out, and have basically accomplished nothing. What am I overlooking? Thanks in advance for any help!
