driftjunke »
https://forums.nicoclub.com/driftjunke-u15361.html
Fri Jun 25, 2004 6:26 pm
We got the RB20 wired up, and tried getting it to crank, we hooked up the jump box since battery was low, Well it turns over, a little hesitant at first, but turns over and keeps turning, but won't crank, we have no vacuum leaks, and all of the sensors are plugged in. Its on a 90 HB, and we used the lower ka harness, and connected the 4 wires needed to be connected, everything is grounded, and seems to be in order. We pulled plug #1, and had no spark. We have fuel and air, so this seems to be the problem. What would be some of the easiest first things to check to see what is posssibly wrong. The motor is a stock motor, and has never been touched so timing should be fine. How can you test the ignitor, the gray oval plug in front of the ignitor the thick white wire shows power, and on the plugs that go into the ignitor, on the passenger side, it has pink wires coming out, and all of the wires are showing 12volts, on the other side, dirver, there are blue wires coming from the plug, and they show no power. With the multi-meter on any of them, it still shows the same thing, no flucuations in power. Does the ignitior sound fine, or is there something else that might be the cause, a wire or something?
Thanks for your help
J.D.
