rb20 turbo help
runaway3087
Car: 1996 nissan s14 with rb20 swap
hey im new to this but anyway i have a rb20 that was from NC. the turbo is going out and is leaking oil. I want to put the 25 turbo on it but do i have to do anything else to it if i do this? I live in south dakota and was wondering if anyone knows where i can take it to get it worked on. maybe around denver, minneapoils, or chicago.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
should bolt up if i remember correctly
KA720
Car: RB powered s13
it all bolts right up, take the wastegate actuator from your 20 turbo and put it on the 25 turbo so you'll still be running ten pounds of boost instead of only 5 pounds from the 25 actuator
runaway3087
thanks for the info., can u tell me anything else i would have to do to the engine?
90240sxca18
Car: 1990 nissan 240sx ca18det
it bolts right up. do what he says about the acuator. i have a rb25 turbo on my rb20. however my car is slow as balls.. it makes like 145hp with the rb25 turbo on it, runs very very veryv ery very very very rich. god knows why tho. lemme know how it runns after you put the rb25 turbo on. im interested.
90240sxca18
get ur rb20 turbo rebuilt. and ill straight up trade you for my rb25 turbo, no leaks no shaft play. full boost at 2800 rpms.
