Acecool »
https://forums.nicoclub.com/acecool-u46759.html
Sun Nov 18, 2007 4:54 pm
Lets see, you would need several things...
Remove the clutch pedal - block holes - 1 to 2 hours (with removing all lines, dropping the steering column and so on...)Replace brake pedal, unless you want the small one. (10 to 20 minutes)Wire up auto shifter (assload of time if you do not know what you are doing)Replace transmission / driveshaft... (several hours)
probably looking at a grand or so with parts, but I do not know so...
