rb20 trans on an rb25 engine?
dcdrifter
Does anyone know if an rb20det trans will bolt up to an rb25 engine. I heard that it will and if you can get one no driveshaft modification is needed. Is this correct?
YamaOni
Car: Its ugly and green, Its a cefiro dori machine
It fits but the end that goes into the 25 mission has to be cut off and welded onto the 20 shaft. Thats what you have to do to get it to work on a R32 as for a s13 or 15 you might need more cutting and welding.
