Bluefire »
https://forums.nicoclub.com/bluefire-u7784.html
Fri May 09, 2008 7:03 pm
Check to see if the pressure plate is releasing the clutch plate all the way. it could be a leaky clutch line, bad slave, or bad master cylinder... A transmission thats going out will rarely grind all gears...
-Bluefire
