After a very, very long 5 year break from the 240, I'm trying to get it on the road again. Sadly it has been sitting with little attention from me. The car did crank and run with a massively high idle. Pulled all of the intercooler piping and found a massive hole in a coupler. Working on swapping a Quest alternator at the moment but I think I've got that under control.
Anyway.. on to my question. I am trying to set the TPS to the correct voltage and through some research, I am reading that the plug directly on the TPS should have 3 wires running to it. Mine only has 2. One in the upper spot, and one in the middle. Is this correct? I've had this engine since 2004 and it has always been this way. I certainly have not changed the wiring. Here is a picture:
Nice to talk to you guys again and thanks in advance for any advice!
