i need the wiring diagram for a rb20det tps.... I have a black connector 3 wires,,, and third yellow wire just hangs off and is not connected to anything and I can't find the other end of the wire anywhere under the harness or mainfold.
what can i do should I just make the yellow wire longer and just run to the an ecu pin to whiever pin number it has to go??? by the way its an auto ecu but its 5spd.
