Hey,
I'm having a problem with my Idle and setting the timing.So I started checking the TPS sensor and it was not set correctly and I am NOT receiving any resistance between TPS pin # 2 & 3.
I've now set the TPS voltage to .5 Volts closed and 4.22 Volts open.
Also I've getting 5.12 volts to the TPS
Right now I'm getting CODE 43
Is my TPS bad???
