RB20 to S13 wiring trouble , you can laugh if you want...
ka24eracer
Car: 180sx...
Since I cant find a clean rb20 harness to send to Carl H for now , I tried to do the wiring by myself on the hacked one I got . With the help of the write-up we got here , I did a part of the engine bay harness but I still cant find some wires. This I where I need your help guys ....:
RB black\pink stripe( doesn't seem to be on the two main plug)The white\red stripe wire ( Cant find it on both side , KA and RB )The Thick White near the FB ( I found about one millions white wire underneath the FB so Im really confused ...)
I would like to know something like where they are on the harness or what the connector look like. A pic could be also a great answer ! Thanks for your help and sorry for my bad english ! Please dont tell me to search , I swear I know by heart every write-up and Im still stuck. And yes , when I ll found a clean harness I ll send it to Carl H for a clean and functional harness ....
ka24eracer
Car: 180sx...
Nobody knows which wire im talking about in the conversion chart ?
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
black/pink is for fuel pump. Check the main ecu plug. As for solid white i don't remember.
BoostFab
Car: S13cp, S13fb, S14z
ka24eracer wrote:RB black\pink stripe( doesn't seem to be on the two main plug)
this black/pink on the rb ecu harness, near the ecu, run it to the brown plug by the fuse box/battery.
ka24eracer wrote:The white\red stripe wire ( Cant find it on both side , KA and RB )
if you can't find it, it may not be needed or not part of the wiring. zerothread?id=92829
ka24eracer wrote:The Thick White near the FB ( I found about one millions white wire underneath the FB so Im really confused ...)
you need to look on the prints on the fuse box cover, and identify the one that label IGN SW, and pop out the lower portion so u can get to the wire, remember to connect the rb White/purple into the left side that is after the fuse. and btw! you need to read the instructions in the write up correctly, otherwise you'll confuse yourself.
ka24eracer
Car: 180sx...
Thanks alot for your help ! That was the part I could not find clearly in the write-up ...! Your post should go in it.
