rb20 to s13 mounting problems
bigfootap
Car: 1991 240sx coupe
I'm at the point in my swap where I'm finally putting the engine in but can't seem to get anything to lineup. I'm using the rb20det mckinney mount kit. I've hammered in the starter area and even some of the surrounding area and it still seems to be catching but I have no idea.
I'm not sure what to do now.
Any advice would be great.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
unbolt the driverside mount from the motor and get the left side down and in then do the driverside that might help.
bigfootap
even when i unbolt the drivers side i can't get the left side far enough back to get it on the mount.
Wongger
Unbolt the transmission from the engine. Then mount the transmission, then mount the engine to the mounts, then wiggle it until it lines up with the transmission, success. Hopefully. Im in the process of doing hte same thing. I just told you what the instructions say. haha, take pictures, let me know how it works.
bigfootap
I havent had any luck with the transmission hooked up so i am going to give it a try without it. And i will post up how it goes.
Carl H
it cant be that hard to line up...ive installed several engines and never had an issue dropping it in engine/trans combo.you need to support the trans while installing it onto the xmember or the mount kit, if you dont support the tail end it will be nearly impossible to get it to drop in properly.
Seanzyyy
Car: 1990 240sx se coupe
^ seems...logical.
lol
OP any updates?
pics are always nice btw
Yellow4g63
Maybe you have the mounts on the wrong side?
FAST-DATSUN
Call us we can help.............. mack 951-304-9300/1045
