Sil240 »
https://forums.nicoclub.com/sil240-u6842.html
Wed Feb 28, 2007 6:31 am
The pot????
Your Tach will not read properly at all unless you have a resistor inline or you have a 6cyl tach or send it to LS auto.
Assuming you have the stock tach, it is calibrated to read a 4cyl signal, but it is reading an extra 2 pulses per revolution.So it will read higher than it actually is.
If your tach is waivering then there's probably something wrong with the wiring or maybe your car is not idling correctly.
I would go by the SAFC if its reading the tach signal straight from the ECU.
I just bought a aftermarket tach.
