mello88 »
https://forums.nicoclub.com/mello88-u18450.html
Fri Aug 08, 2008 3:54 pm
LOL. I think everyone would rather see your own car sitting 4x4 on stock wheels than that monstrosity
Look in the FSM for the ECU pinout, there is one pin that controls the tach. Find this wire and try attaching your tach green wire to this wire, it may or may not work depending on the tach you're using you may need a signal adapter.
This is probably why none of your gauges are working; whoever wired it didn't take the time to do it properly. As a bonus for your research in the FSM/Wiring guides you'll also find the coolant temp wire, speedo wire and oil pressure light so you can fix that stuff as well. GL
