Coolwhip »
https://forums.nicoclub.com/coolwhip-u13264.html
Mon Mar 01, 2010 5:57 am
we'll need ALOT more information then provided in your post.
What have you checked thus far?
Does the engine turn over by hand?Does the starter get signal and engage?
If it's turning and not starting...Is your ECU getting power?Are you getting spark?Are you getting fuel?Does your engine hold compression?Is your timing belt installed correctly with everything on timing?
It goes on and on... what are you dealing with, the more you explain, the more the group can help.
GL
