Zooeydeschanel »
https://forums.nicoclub.com/zooeydeschanel-u267502.html
Thu Aug 25, 2016 5:40 pm
Pleaseeee help me!!
So my car stopped working one day and after two weeks of stress I got a used CAS and it worked! And then it started to misfire but then I fixed it Because of a loose wire apparently?? but then my car started to act up again 2 days later and it died and would sometimes turn over but always would die after a second. It would only start if you constantly sprayed carburetor fluid into the MAF. The second you stop spraying it dies. I made sure the fuel pump was good(makes a whining noise but tested it and it still works) My fuel pressure is good, my injectors are good and I just cleaned them out and I got new spark plugs so I'm at a total loss because I also made sure my CAS was working and my igniter is working as well and my ECU! I put the CAS, igniter, and ecu on my friends rb20 and his ran good!
I have no clue what's happening with it PLEASE HELP
