Rb20 Swap
Lonismos14
Car: 1995 Nissan 240sx, 1999 Chevy Hoe, 1996 Saturn Sl2
So i have been doing some research for a while now, and im going to be swapping a rb20 into my s14.
I think i have all the knowledge i need but i have one setback. The turbo elbow wont clear the steering rack, i heard some guy in australia will do it but i dont know who. Does anybody know where i can get an elbow?
And also how can i tell if i have a short snout crank?
Carl H
i believe you're talking about the AM performance downpipe/elbow...not sure if andre is still around but his parts are quality if you can find them.
else you can grind the cast elbow or make a custom pipe.
all rb20 engines have short snout cranks...
Lonismos14
Thanx carl just to give you a heads up, im sending my harness to you. :D
Gabes13
Car: rb20det s13
Man, you're getting an rb20 now?
I just bought one.
Plan on putting it in when school's out.
Lonismos14
pandapants wrote:Man, you're getting an rb20 now?
I just bought one.
Yup im ordering mine in like two weeks, where did you get yours from and how much was it?
Gabes13
Car: rb20det s13
Got it from a local who's doing a 26 swap.
1300, mounts included.
RustspecS13
Car: '74 260z and '88 300zx turbo
I have/had an RB20 with mckinny mounts and my stock elbow clears with plenty of room to spare. I did make my own down pipe from the elbow to the testpipe but that was easy.
Or if you don't want to make a down pipe get a syko 3in turbo elbow, and its not only a upgrade (spool faster more hp etc etc) but it also gives tons of clearance and best of all it uses regular sr20 downpipes which are easy to find.
You can also just notch your stocker, and if it gets too much you can have it welded to seal up the hole. Lots of options, thats hardly the biggest problem in the swap.
~Alex
TheRealNap0le0n
Car: 1998 q45
Lonismos14 wrote:So i have been doing some research for a while now, and im going to be swapping a rb20 into my s14.
didnt you just get done tearing your Ka-T apart.... and im sure ur gunna do an RB20 auto swap too huh...
I keed i keed...
neways i still have like a million dollars left to spend on my RB25 but at least its sitting in my garage
Lonismos14
I keed i keed...
Hell yea spent s*** load of money tearing it apart again as in that wasnt my first time doing that. And it blew again so i said f*** that i need something reliable, i should have my motor in about two weeks.
Carl H
my buddy's s14 covered over 50kmi after we swapped it...yes 50k mi.
super reliable car, never left him stranded and was pretty quick after we tweaked it some.
Lonismos14
So one more questions guys. So what do i need to keep from the ka to finish the rb20 swap. :bigthumb:
Carl H
trans sensors (neutral, speed, reverse)
ka lower harness, ka upper harness
ka thermo temp sensor (one wire temp sensor next to coolant temp sensor)
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Drive shaft if it's a 5speed.
Lonismos14
Thanx you guys. :yesnod So i can use the rb20 ac compressor correct. I was going to wait two weeks but i might order in a couple days. :woot:
Lonismos14
Well guys i ordered my motor today the only bad thing is the person said the motor does not have a maf. :frown:
Kevin.A
Car: Nissan 300zx RB20 swapped
you can wire up a Z32 maf, or get a ford cobra maf.
RB25 maf's work too.
you can also spend the money and get an aftermarket ECU and convert your car to map.
Carl H
changing the maf means the ecu needs to be calibrated for it.
e60/e61 maxima maf will work as a replacement but requires a different plug.
Lonismos14
No need to worry i already have a z32, ill just by a apexi neo and calibate the ecu. :mad: I wanted to run stock everything didnt want to get to the neo about 5,000 miles later. :woot:
TheRealNap0le0n
Car: 1998 q45
IIRC i have an extra J60 maf... i have to double check. the RB25 i got came with a N62 maf and another one... maybe E60
Lonismos14
whats does iirc mean and whats the model maf is it because i really dont want to get into modding this motor till down the line. According to ups the motor should be here tommorrow cant wait. :dblthumb:
StryfeS13
Car: 1993 Nissan 240SX
IIRC = If i recall correctly.
