RB20 swap rubbing dump pipe
MATTs14
Car: Red 1995 Nissan 240sx
I just got done swapping in my Rb20 using the the R32 crossmember and hockey puck mounts. The steering knuckle is rubbing the dump pipe slightly and i was just wondering if there is any good aftermarket dump pipe that will clear the steering knuckle. I want a divorced dump but will take anything that will flow better. Any suggestions?
I found this. http://cgi.ebay.com/ebaymotors....m245
nissans13240sx
Car: 90 R32 GTR
91 Hatch SR20
93 Coupe KA-T
04 STI
Common problem. I dont think there are any aftermarket pipes that clear. You can either notch it or switch mounts. Ive noticed mckinneys clear pretty well.
nissandrftr88
Car: 34 240'S, 3 rx7's, 06 & 07 gsxr 1000
Just do a custom downpipe.
cdorhout
Car: RB30DET with VCT -- SOLD!!!!
Next project TBD
Syko elbow combined with a common SR20 downpipe clears just fine.
MATTs14
Will this line up with the rest of my exhaust if i use the syko and an sr20 downpipe? I just didnt think it would work with the r32 crossmember
ANVIL
Car: RB25DET S13.5
i notched mine and it works fine. ill redo it when i get a new turbo, if its not a direct bolt on
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
It will work. The only difference is the turbo elbow. It has been modded to avoid interfering with steering. Otherwise it just fits to the rest of the exhaust.
MATTs14
Well i did grind it down i was just wanting something that will flow a little better. Any suggestions besides custom?
nizmo zilvia
Yes there is something for $325 from Australia but if you can do it custom it would be your best bet. Not only will it be cheaper but you will have it fit 100%.
MATTs14
ok i guess i'll just wait until i get a new turbo. No need in spending all that money now and then turning around and having to have another made. Im probably just gonna get the greddy mx downpipe to increase flow
MATTs14
Yea thats what i'll probably do. Im gonna do the gt3071r with v band
