rb20 swap questions...
sleepyeyed240
Car: 1993 rb20 vert, 1989 hatch
i have a 92 240 i was thinking about doing the rb20 swap but i wanted to know what all you need besides the engine... i tryed searching but couldnt find anything. help me!
Hijacker
Car: '92 240sx Convertible
'94 F-150
Obviously you didn't search hard enough if you couldn't find the RB forum
He's all yours, RB guys
tjmhillz
Car: 2001 Lexus IS300 Turbo
hahah FRESH MEAT!! if u search around here theres a sticky at the top it should help you out.. it tells u everything you need good luck wiht the swap if u do decide to go with it.. i should be starting mine very soon. rb20
AxiOn419
Car: 1991 240sx SE Super-Hicas w/ RB20DET
Are you serious? The thing about you searching was a joke right? Even if you didnt search within this board specifically you still should have investigates the boards available to you before posting. All of the information you need is stickied at the top of this forum. But whatever, I am willing to answer your question with a very brief answer.
You need:Motor set (motor, transmission, intercooler, ecu, wiring harness, all other sensors)Motor mounts - search this board for infoIf your car is an auto, you need a M/T drive shaft, or a one pieceIf you cant do it, you will need someone else to do all of your wiring.Time - have more than you think you will needMoney - have more than you think you will needPatience - have more than you think you will needKnowledge of how to properly search the NICO forums - you may struggle here
Hope that helps
Carl H
stickies are a good place to start.
sleepyeyed240
i did search but all i found was a bunch of **** i wasnt looking for... i just wanted a straight answer. and i got it haha
