Rb20 swap--oil pan
240240
Swapping an rb20det into my s14 but have run into a problem. The oil pan is resting to the sway bar and crossmember preventing the motor to lower anymore and thus the motor mounts are not touching. Anyone else run into this problem?? Help!! Will taking the crossmember from the skyline clip fix this?
Thanks
Wulfgang
If you are using aftermarket mounts, then maybe you should call the person who sold them to you.
If you are using your stock KA mounts and KA crossmember, then I have no pity for you.
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
if you are not using mounts then you have to use the RB X-memeber.
240240
Got the custom motor mounts, designed to lower the motor and bring it forward--they are identical to the mounts that came off the Skyline, just shorter so the motor sits lower. Looking at both crossembers the 240sx goes straight across whereas the skyline as a bend in it to accept the oil pan
240240
The guy I bought the mounts from said I could use my stock KA crossmember!!
Project240
Forward? What motor mounts are supposed to bring the motor forward so that the shifter is even further away from the center of the hole??
I think you've got the X-member backwards, chief.
240240
I dont That the mounts could go the other way--Im going to check but the way the motor is setting now there is hardly any clearnce in the back
240240
Yeah the mounts wont work the other way- the steering linkage would be in the way
