Rb20 swap into an s14. Auto to manual converted? Which lower/transmission harness?
SuicidnS13
Car: SC300 2jz, 93 Vert (RB), AcuraTL
Will I need an s14 5 spd lower harness for my rb20 swap? Also is the ka24de automatic engine harness different from the 5spd engine harness? I still have the s14 engine harness but threw away the auto lower harness.
PorkChopExpress
Car: rb kouki
dont need it, you use the one from your rb. the at/mt ka harness, who cares it gets pulled
Carl H
it is best to use the lower harness from the car that is being swapped...saves headaches.the 5spd lower is different than the auto; ideally the auto would be used and adapted to the rb block.
Carryl
I used my automatic...s14 lower harness didnt have to change anything; i used my sr20de alternator though and an sr20det speed sensor in the gearbox.
PorkChopExpress
Car: rb kouki
oops, is the lower harness the the starter,alternater connections? if so, ya i used the one from the car. cant remember any problems using a auto harness.
SuicidnS13
which speed sensor will I need to use for this setup?
smitty4130
Car: 95' S14 w/RB20DET, 03' BMW 330Ci
will the speed sensor off the rb20det transmission work? Also it looks like there are three sensors on the rb transmission, will they all work as is?
SuicidnS13
smitty4130 wrote:will the speed sensor off the rb20det transmission work? Also it looks like there are three sensors on the rb transmission, will they all work as is?
Are you asking me? Im in the same boat as you. I dont want to get started with this swap till I know I have everything I need to get it in and running on one try.
smitty4130
Lol, I'm asking everyone because we're in the same boat. I'd rather not open another thread with the same topic.
yotik
Car: 240sx Hatch
Im using the one off the ka24e. It drops right in. The one from my Rb was cut so that didnt work out. Carl did my upper wiring harness, so the ka lower harness snapped right in.
smitty4130
So all the sensors on the rb trans worked good with the ka lower harness?
yotik
Car: 240sx Hatch
smitty4130 wrote:So all the sensors on the rb trans worked good with the ka lower harness?
im not sure i havent got that far yet, maybe someone else can help you with that part lol
