rb20 swap into 97 240sx
DaR
Car: 97 240sx
hi, im wanting to swap a rb20det with a 5 speed into my 97 240sx that is automatic. has anyone done this before(with the trannys), im looking for advice.
thanx
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
yes its been done. there should be plenty of info in the search results.
The short of it is, youll need a drive shaft from a manual s14. If you have ABS, then you need a driveshaft from a manual with ABS. You will also need the clutch pedal assembly, the clutch master cylinder and the hard lines. Don't forget to get a s14 manual transmission speed sensor with the correct gear attached. I think you may have to bypass some switch so the ecu thinks you have the clutch down in order to start it. I may be leaving out a few things, but thats all I can think of off the top of my head.
Joe
search search search
