RB20 stopped running and now won't start.
blues14
Car: 1995 Nissan 240SX GTS-t
So my 240 has been sitting for about 2 weeks without being ran. It took a bit, but finally started. I let it idle for about 5-6 minutes, then turned it off. About an hour later, I went back out, it started right up, let it idle for about 3 minutes and took it around the block. I gave it a little gas (bout 5 psi) and then it started smoking and sounded like a wrx so i went straight home, got it in the driveway and turned it off. now it wont start at all. I have a fuel pressure gauge inline, and when you turn the key, it jumps to 40psi, then drops to zero. WTF? In 4 years, this is the first time i have had any trouble. I have a nismo FPR and a walbro fuel pump. any ideas??
Joe
just like any no start, start with the basics
air, fuel, spark.
verify they are getting INTO the cylinder. not just that there may be fuel pressure for example.
blues14
I only have fuel pressure for about 2 seconds.
Carl H
pump is are dead.if it builds pressure for a second but does not sustain then the pump has gone bad...
Joe
blues14 wrote:I only have fuel pressure for about 2 seconds.
is the pump turning itself off? (check voltage at the pump)
how is your engine wired? if its hard wired it should run as long as the key is on, if its run through the ecu it will only prime for a couple seconds.
if its priming then losing pressure you have a faulty drainback valve in the pump but that SHOULD not cause the engine to not run. i had a failed drainback valve in a walboro for over a year before it finally completely failed.
blues14
its the same when either just turning the ignition on or actually starting the car. Pressure for 2 seconds, then pressure drops to zero.
PorkChopExpress
Car: rb kouki
my walbro does the same, the lines dont stay pressurized.
blues14
Ok, figured it out. The injector on cylinder 3 went bad. Here is what i siphoned off the piston.
about a cup worth of gas!
so i am having the injector rebuilt next week, compression is about 140 accross all cylinders (cold)
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
lucky S.O.B! almost hydro locked your block.
Cjmartz2k
Car: Hunting for a '89 GTR now
Well, I'm sure it was hydrolocked if it wouldn't turn over, but that in and of itself isn't that bad. Getting a lot of liquid (fuel, water, etc) into the cylinder while the engine is running is what turds them. Your starter motor doesn't have enough tourque to bend a rod or **** a piston. The momentum of your motor/drivetrain sure does though. I found that one out the hard way in my jeep after about 12 beers and a "hey watch this"
lazyboi444
Car: 240sx Hatchback
I have a question for you if it was a cups worth in that cylinder. Where was the piston at on its stroke?
OKRB20DET
Car: 1990 S13 coupe
looks like HALF a cup worth to me
Carl H
some gross gasoline there.what injector brand was it?
blues14
deatschwerks......i called them. They had me send in all six to replace them all for free.
240z4u
Car: '95 Nissan 240SX
Change your oil NOW!
Guarantee lots of fuel ran past your rings.
Evan
raremotive
Car: 04 Infiniti G35
240z4u wrote:Change your oil NOW!
Evan
I second this notion.
blues14
definately will change the oil and filter before starting it back up. the spark plug should be ok...right?
