RB20 stock turbo identification
1sikS13
Car: 1992 S13 240sx
got a used stock RB20 turbo...but it has no wastegate regulator or bracket...so i was looking on frsport and they have new ones on there but i dont know what the stock turbo is gt30 gt28 any help would be appreciated....also what is the stock wastegate spring rate?
DriftX
Car: '89 240sx
It is a t3 flanged t28, stock rb20 spring is set at 10-11psi and the stock rb25 turbo actuator will bolt on, but it's set to 7psi.
I'm sure someone on here has an oem actuator.
1sikS13
Car: 1992 S13 240sx
they have them on frsport.com im just debating which one to get some are universal but they are like 80 bucks for the actuator and 9 dollars for the bracket which i need both. and also can i turn tho housing to face a different direction to fit my KA or is this turbo the kind that wont allow that or can you do that to all of them......also where can i get a 6 bolt elbow to bolt to this thing....thanks again
mello88
Car: s13
I have a stock RB20 wg actuator and bracket if you want to buy. Not sure about the clocking, I think the stock turbo does not allow this but it's been a while since I looked at it.
For the 6 bolt, there are a few SSAC elbows on ebay, and also you can re-use the stock cast elbow outlet. I have a SSAC elbow you can use, or chop and reweld to your custom DP.
1sikS13
Car: 1992 S13 240sx
sent you an email...hit me back
