skillzilla »
https://forums.nicoclub.com/skillzilla-u17041.html
Sun Sep 24, 2006 6:30 pm
SO Im getting sick and tired of working on my car and spending money on it when nothing seems to fix my issues. Basically, its pulling timing any time Im in boost. Motor will make and hold boost fine and rev freely but has no power.
Anyways, today I put new plugs in and made sure my adjustable cam gears hadnt slipped. Cam gears were fine, new plugs actually made it WORSE. So I pulled them out, gapped them smaller (to .027) and put em back in. Basically, it runs exactly like it did. Runs fine if Im not boosting, and wants to fall on its face if I am. Checked for boost leaks and I have one teeny one on a weld but thats it. Also swapped in the stock S13 fuel pump thinking it was getting too much fuel, as the old plugs reeked of gas and it always burned a lot of fuel. Fuel pump semmed to help a little, and the plugs came out a little white after 15 minutes of hard driving, but no gas smell.
Anyways, I am fed up and taking one last test run after restting the timing to 15 degrees and I pull over at a gas station and pop the hood. I look in the bay and the turbo is freakin glowing like red hot, crap you see in magaizinges and stuff. Im like wtf?! So Im wonding, what is making the exhaust so hot? Timing too advanced? plugs gapped too narrow? Im at a loss, if anyone can help please LMK.
