RB20 starts and dies-HELP please!
Red93coupe
Car: 1993 CA powered Coupe-sold 1996 Maxima 5spd all black, 1992 300zx all black 2+2 soon to be TT
ALright we are working on a friends RB20 and when we start it it runs for no joke like 2 seconds and then dies.....You can keep doing it over and over and it does the same thing.... It has new spark plugs, there is power to the coils and power at the ignitor so I don't get it!!! Any suggestions. The other part I keep telling him is that he did the wiring himself and it is a rats nest, I think he has wired something wronng but what???
nizmo zilvia
Car: 95 240sx w/ S14 SR20 Blacktop
Yea maybe his wiring sucks. Kinda hard to guess what the problem is. MAF working? Even at that it would be in limp mode. Umm... maybe the car has trouble idling? There could be alot of things.
Red93coupe
Well its like no fuel or something but you can here the pump prime up, he has a nismo regulator but he never set the psi, how do you do that in an s13? maybe?
nizmo zilvia
He has Nismo Fuel Pressure Regulator?? I didn't have mine set and just installed it out of the box and the car ran. It didn't run good but it ran. I doubt its the FPR.
Maybe his fuel lines are reverse. It happens all the time. So check that.
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
if im understanding you correctly the way to set the fuel pressure is first ur gonna need a fuel pressure gauge whether its an in cabin one or one that has to go in the engine bay.after that you just udjust the srew on the fpr up and down untill the desired pressure.do you have a type A or type B regulator?A type A goes on directly to the fuel rail a type B can be put any were.
Red93coupe
He has a nismo fpr I dont know the MAF is plugged in and we have tried two other ones.....I'm starting to think its his wiring it is so bad...Another thing could it be the Injector resistor or is there one I haven't looked closely yet and I'm at work so I dont know right now!?
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
Ill put money on it The fuel lines are backwards!!!! Had a buddy do the same thing.
leesredgt
wouldnt it at least idle though? i mean i dont know im just askin?also rb25drag not to thread jack or anything but were are u located in springcity?i only live 10-15 min outside of chattanooga.i do alot of work up that way my dad works for tri-state pools so we go were ever they tell us to install above ground swimming pools.
rb25drag
leesredgt wrote:wouldnt it at least idle though? i mean i dont know im just askin?also rb25drag not to thread jack or anything but were are u located in springcity?i only live 10-15 min outside of chattanooga.i do alot of work up that way my dad works for tri-state pools so we go were ever they tell us to install above ground swimming pools.
No it wont idle it just burns the fuel it has in the fuel rail then shuts off.
Ya I live in springcity and work in Cleveland. If your ever down near springcity give me a holla!! 423-619-4842 My name is Scott.
It would be nice knowing someone from around here.
All I ever see is Honda crap guys so all I hang out with is the v8 guys lol.. They know diddly about our motors!!! But they know I hand it too them at the track
Red93coupe
Well heres the other thing the week before we had it running and it would surge but wouldn't die but now it just dies right away......confusing isn't it.....I will make sure he didn't change the fuel lines in the last week or so but I dont think he did.... Which one goes where then if he did move them?
leesredgt
al right man next time im up that way or else tryin to get some kinda of car gathering goin ill give you a shout!!!!
