shonanspeed »
https://forums.nicoclub.com/shonanspeed-u98796.html
Mon Jun 09, 2008 4:40 pm
I have searched through the threads and found some posts with issues similar to mine but there seem to be more symptoms with most.
This is what im facing...New RB20 install in a S13. 1- Motor will crank and crank all day with no result but if i use a bit of starting fluid it will buck and then start when i stop turning the key. Once it starts it idles fine, no bucking or stuttering at all. As soon as i turn it off it starts the whole cycle again regardless of how long it has been running.
2- motor idles fine but when reved up it feels like its hitting fuel cut at about 1/4 throttle im assuming its about 2500 RPM's. The ECU is flashing a diagnostic code for the MAF. I cleaned the MAF, double checked the MAF wiring...shielding is intact so im wondering if anythig else could cause this before i buy a new MAF.
Biggest problem is the car is in Florida and i live in Virginia so my last three weekends have been spent flying down and working on it. The airfare is going to end up costing me more that the swap did! Any help or ideas would be greatly appreciated.
