hey iam running a rb20 in my s13.
there are 4 wires from the gearbox, 2 i have hooked up the the reverse light. the other two do they go straight to ecu pins, for vehicle speed senor ? and a sensor ground also on the ecu.
currently its hooked up to a rev speed meter, and gets no reading. one being plugged to the rev speed meter (signal) and other i just grounded straight to battery ? should this work or does the ground have to go to the signal ground pin on the ecu ?
edit. iam not running it to my cluster at all. so dont worry about that.thank~
