I ran R32 crossmember with my RB20 and used an S13 AUTO transmission crossmember on the RB20 manual transmission without issue.Carl H wrote: the auto box mount is ONLY for the 25 box, will not work with the standard 20 box iirc.
I'll try that. Thanks to all of youST240 wrote:I ran R32 crossmember with my RB20 and used an S13 AUTO transmission crossmember on the RB20 manual transmission without issue.Carl H wrote: the auto box mount is ONLY for the 25 box, will not work with the standard 20 box iirc.
Go to a junk yard and find an s13 auto transmission crossmember and your problems will be solved.
