RB20 S13 Powersteering
s14Geoff
Hoping someone can help me answer my question
ive got the powersteering modified (fins removed need to get the bolt welded still)
ive read that you can use the stock lines, but how do you get the high pressure line to the pump?
the line comes on the left side of the bay but the powersteering is on the right
running under the engine theres not enough length, infront theres no enough length. do i bend the hardlines?
Im wanting to avoid buying a kit if possible, thanks.
Syrus33
Car: 1993 Nissan 240sx Hatch
RB20DET
was your car single or dual cam?
s14Geoff
It was a single I read somewhere you need DOHC lines?
Is there anyway to make these work tht you know of or do I have to buy new lines
Syrus33
RB20DET
as far as i know you need the lines from the dual cam as they are on the right side and bolt right up to the rb20 pump. Mine was a dual cam with hicas so everything bolted right up.
s14Geoff
Ah alright thanks man!
