-Curtis
So there is no other option? I would like to find another option, whether it comes to me deleting the brake booster, or modifying the manifold that I have. I haven't seen very many topics, though I could just be missing this.Yellow4g63 wrote:Stock manifold.
When I bought the motorset, this is the manifold that was on it. I would swap to a stock manifold if I still had it. I've tried looking into other aftermarket manifolds, the problem that I'm running into is that most of the ones that I have found set the turbo farther back. I've seen a few, like the 6boost or RAW brokerage one that place it farther forward on the motor, but those are both pretty pricey. I understand that you get what you pay for, but at the same time I can't justify paying big money for a manifold, when I picked up the motor/2 trannys/ecu/harness/ls coils/etc for under a grand. I guess it looks like it will come down to trying to modify this, or moving around MBC.Yellow4g63 wrote:Make the car RHD because it looks like the manifold was made for that car. Put the stock manifold on it has a T3 flange already. Just add the external gate to that manifold and you should have better clearance. Or get a different manifold that put the turbo in the middle of the motor or towards the front.
Yellow4g63 wrote:http://www.ebay.com/itm/CXRacing-Turbo- ... 06&vxp=mtr
That one is cheap. Find someone with a rhd car and sell that manifold. And if your on stock S13 brakes don't even bother driving the car till u upgrade to Q45's or Z32's.
