blues14 wrote:thanks guys, i will give it a shot. is it difficult hooking up the coolant temp gauge? where does the probe go?
I retapped the bleeder port on the top of the intake manifold. It was not particularly difficult.
use whatever tap is appropiate for whatever brand gauge you get. For the autometers it's 1/8 npt. (1/8-27) and for the jdm-ness is gonna be bspt(no idea what that works out to)
use the proper drill bit for your tap, and dip it in some vasoline so most of the metal shavings stick to it, and drill the port out.
dip the tap in vasoline for the same reason, and carefully tap that &hit out, rembembering to back it off 1/4 turn every 1/2 turn.
get about 50 q-tips, and dip those in vasoline, and use them to blot out and metal shavings that might have excaped.
screw in the sender with some teflon tape, but be careful not to meathead it too bad, because those threads are pretty soft, and there are passages you could potentionallly block if you screw it in too far
wire it up and find out how hot you are really running.
