Cpt_Impossible »
https://forums.nicoclub.com/cpt-impossible-u43114.html
Thu Mar 29, 2007 4:34 pm
I have been struggling with an overheating problem strictly at freeway speeds for almost a year now. I have tried just about everything but if I dont blast the heat and take it really easy, the car will overheat at freeway speeds. Yes, I know that it is overheating because it has topped out before and spewed fluid. Also, I can see the fluid level raised int he resivoir after a freeway drive. The car has no problems blasting around the streets, but the continual 3k or so on the freeway just kills my engine. I have tried:
System is fully burped, does not require any filling after drivingUpper rad cooling panelLower Rad Cooling PanelNew Radiator CapNew ECU temp sensorNew OEM ThermostatTwo 12" E-fansCutting out the pignoseHonda OEM coolant with distilled water and water wetterKoyo Radiator
I recently took it to a shop and they said that the pump and headgasket tested out fine, that coolant was flowing just fine (as evident by my blazing heater) and they thought the FMIC was just blocking too much air to the radiator so they had me cut out the pignose. Ive done that now and there is still a problem. 90% of the air that hits the fmic has no other option than to go to the radiator because of the upper and lower cooling panels I have added and at freeway speeds, I would think with all the ducting the radiator should be getting plenty of air. And besides, the car overheated on the freeway with the side mount intercooler I had too.
So I got to thinking and searching and I found that a lot of other cars have overheating problems when the lower radiator hose gets old and soft and then collapses under the vacuum created by the pump's constant sucking at freeway rpm's. Most manufacturers seem to install a spring inside the hose to keep it's shape under these conditions. My lower hose is soft and I was wondering if this is a feasable cause of my problem. I am thinking of getting a Mr. Gasket SS ribbed hose to replace mine because I think gettign an OEM one will be a pain. The appropriate length hose from Jegs though is around $60 and I dont want to waste the money if my theory is flawed.
Any thoughts?
Modified by Cpt_Impossible at 3:31 PM 3/30/2007
