rb20 running problems
jwlong1379
Car: 240sx
when i start up the motor cold it runs great...after about one or two mins it starts to idle like crap and back fire... also has almost no throttle responce
i have checked for vac leaks and i have also checked for boost leaks also timing
no idea what it could be please help
spin
Car: 1989 240sx
you should check your plug and if its fould you could try to go with a colder plug its a good chance it could be your plugs
craz4240
Car: 1995 240sx w/rb20det
Coils.....check your coils.
skrappy
Car: BNRPS13
check the plugs, coils, and fuel filter. If none of those check out then go to the MAF
240z4u
Car: '95 Nissan 240SX
Colder plugs foul easier.....
Stock plugs should work fine.
Evan
You may consider testing your coolant temp sensor as well.
mott6904
Car: rb20 big turbo big cams s13, 97 kouki, turbo audi a4,turbo busa
I had the same problem when my tps wasnt set right. Is this the first time you started the engine or did it just start? I would say is a boost/vac leak, timing is off, tune up, dirty injectors or maf, or tps isnt set right.
