nekoabandoned »
https://forums.nicoclub.com/nekoabandoned-u106457.html
Wed Jun 17, 2009 12:01 am
lean most of time , and yes haha.heres a better question, would the ecu not getting a rpm signal cause it to run lean? cause at the moment im not getting any voltage through pin7 ....the guy that i got the harness from did a real hack job on it, so ive been stuck running new wires all over the place. is there a chance that the signal wire the computer uses to convert the signal from the cas to the tach has been cut and could have been causing this issue ?thanks
Modified by nekoabandoned at 3:12 AM 6/17/2009
