rb25det250sx wrote:underneath the intake mani, there is two sensors on each side. crank position sensors or sumthing like that i think... anyways, i know that on my rb25 swap they weren't hooked up, and my motor was running of safe mode. so i hooked them up and i;ve been fine every since. sorry for the somewhat long post. but check those out! i think it will help.
BTW the wires that go to it on my rb25 are brown, and they have a power wire running through them then they are rapped around by a ground wire, then covered in the brown.
i dont believe the rb20 has these sensors.
kickertu wrote:Has no one brought up the s-afc issue?
if you just installed it and are now having a maf issue, or rev limit then it sounds to me like your s-afc isnt either hooked up correctly, or isnt set correctly.
take the s-afc totally out and fix the maf part of the harness. see where its at without the safc. also for the missing part of it, the fuel map might be messed up on that part of the afc.
good luck on figuring it out, but from what i read, sounds like the issues started happening after you put the afc in
ive tried unplugging the afc and jumping the 2 wires to bypass it and still no dice, afc was on stock settings and worked fine for over 600 miles. tired a new maf today and nothing, tryed another ecu and tryed my ecu in another car... nothing. tried jumping signal wires and signal ground for maf to ecu direct to theyre pins and nothing. it runs the same with maf or not, 9.0afr, and if i rev it to 2500 where it stops and let it bounce it goes straight lean to 16-20 before i stopped. im stumped ive tried everything, i bought another harness months ago but the dude hasnt had a chance to ship it. hopefully he can asap to rule that out, also bought a timing light but had to order it in, messed with timing and same thing.
