RB20 rough start
ST240
Car: RB30DET Nissan S13
'01 Nissan Pathfinder
Other than starting, my rb20 runs like a god damn champ.
What happens is when i turn the engine over a have to crank it maybe 5 or 6 times. At this point in kinda sputters and putters and its BARELY running, it does this for 2 or 3 seconds then the idle jumps up and it starts purring like a kitten. Sometimes its kinda hard to get it started tho.
Anyone have any idea what the problem is?
240daveTX
Car: 2005 Nissan Titan LE
1993 Nissan 240SX Convertible
we need more info on what your motor is in. s13 sohc, s13 dohc, s14
ST240
its an 89 so sohc s13, also it was previously auto.
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
check your intercooler piping for any boost leaks, and also did you already set your base ignition timing and fuel psi?
PorkChopExpress
Car: rb kouki
mine does this because i dont have a constant 12 volt to the ecu. so when starting it thinks its running instead of doing its starting procedure.
dont know where to run the 12 feed. let me know if you find out.
ST240
I did not set timing, however i set fuel pressure.
It also only happens on cold start... Once its warm its starts right up.
HxC_Nismo
'07 Nissan Titan SE
'05 Toyota Corolla
do a compression test when cold, cause if it is fine when its warm there is a chance your rings are starting to go bad.
ST240
HxC_Nismo wrote:do a compression test when cold, cause if it is fine when its warm there is a chance your rings are starting to go bad.
I could see this being a possibility if it ran poorly until operating temp, but it only struggles for a few seconds and starts idling fine right away...
RustspecS13
Car: '74 260z and '88 300zx turbo
Do you have the orange cold start wire connected?
zerothread/328569
Look at the post near the bottom its in there.
~Alex
ST240
RustspecS13 wrote:Do you have the orange cold start wire connected?
zerothread/328569
~Alex
I most certainly do not. I bet thats what it is. Thanks man ill go try it!
RustspecS13
Yea it helped out a lot on my rb20 starting up. I also always let my fuel system prime most of the time. That helps out too.
~Alex
