RB20 rod bearings
sileighty89
Car: 89 240sx hatch & 89 coupe
Anybody know what the part number is for the rod bearings on an rb20det, or from what other nissan will work as a replacement
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
You might want to try the Down under skyline forums for that info.
gawdzilla
Car: none
mains are:12207-42L10 through 14 depending on thickness for the regular bearings
12261-42L00 through 04 depending on thickness for the thrust bearing
rods are:12111-58S00 though 02 depending on thickness (grades 0-2) respectively. if you want odd size bearings they are different p/n's
nothing cross references with the US
sileighty89
cool thanks for the part #s ill try to order some but in the meantime im gonna go pick up a longblock on monday since venus is only 45 minutes away.
Sil240
Car: Nissan S13 "The One Cam Wonder"
sileighty89- did you find anyone that had the bearings? Because I ordered L series bearings but they were the wrong parts.The Dimensions are exactly the same but the tangs for the bearings are in the wrong spot and the Thrust bearing is too wide.So right now im looking for Main bearings (black) and Rod Bearings (Neutral)
Shoot me a e-mail if you find anythingThanks Brian
[email protected]
Sil240
As of right now Nissan Japan is out of stock, they are back ordered till Sept 15th.Right now I'm trying to get them from Australia.If anyone knows of someone that has them please let me know.
