RB20 rev issues
Monkey87
Car: 1995 240SX SE/RB20DET
So, my RB20DET was in really good shape when I bought it. Ran fine, internals were clean, compression was good....and then a few weeks ago I noticed a power loss in the higher RPM range. Now, when I crank the car, it idles a bit rough, and it also will not rev over 2500 RPM. When it hits 2500, it will die back down to idle speed. If I hold the throttle down, it just does this over and over. A friend of mine suggested that the turbo was overboosting, causing fuel cut. I don't have the equipment to test it myself, so I wanted to know if anyone could help me out before I spent the money to take it to the shop. Anyone got any ideas?
Sil240
Car: Nissan S13 "The One Cam Wonder"
Check to see if you have a boost leak.Check all of your couplers.
Carl H
maf or maf wiring fo sho.
jaxiss
Car: 92 240sx coupe{sold)/ 05 altima(gone with the x) / 91 sonoma(sold)/93 s13 vert(for sale)/ 98 z34 monte
yep deffinitly a problem with the maf. an old KA i had did the same thing and i found that the wire clip to hold the plug on the maf had gone missing and the harness had fallen off.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
maf all the way!! even if that goes away at idle. You'll soon find that it will just sputter and die on you while coming to a stop. Good luck bro. Get a new one.
NewfoundlandDude
Car: 2001 Nissan Maxima SE - 20th Anniversary Edition
If you can get your hands on another MAF to test it out first, do so.One of the wires may have broken inside the insulation or in the clip, and if you can save yourself the $$ then borrow one.
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Hmm sounds like a maf to me too.
eh?
I gotta disagree with the others and say it's the AFM, not the MAF
Check your maf wiring
Yellow4g63
eh? wrote:I gotta disagree with the others and say it's the AFM, not the MAF
lol
