mott6904 »
https://forums.nicoclub.com/mott6904-u55683.html
Mon Mar 30, 2009 7:30 pm
Dont put that in any of the holes on the front of the block you will screw yourself. There is a 8 or 10mm allen bolt in the bottom of the pump. Pull the spring out and slide the sleeve over top the spring, then slide the spring back in the pump starting with the sleeve.
