rb20 racing and cooling
wabisuke1
anybody have any recommendations on ways to cool a rb20 being used as a for road racing. i already know about the koyo rad and n1 water pump. any ducting suggestions hood modifications. i read the thread on just cooling suggestions already but it still kinda left me with a blank. thanks for your answers ahead of time
maryjane
distilled water and water wetter in the rad. lower splash gaurd between the i/c and the rad support, good fans or stock fan with stock shroud, BLED cooling system!!!!!!!!!
wabisuke1
i' ve never heard of water wetter in a rad what is that. and do u mean use distilled water instead of coolant or a mix of the two which i think u mean thanks for the reply
DRFERO
Car: R32 skyline GTS-T typeM
i run a triple core alloy race radiator with 2x blowing electric fans...no heater core conected and new waterpump/coolant/thermostat etc.i can sit my car on the spot in 3rd gear and do oz till the tyres pop and dont get any overheating wat so ever
maryjane
water wetter is a coolant additive, its by red line. use distilled water b/c it is filtered and dosent have any minerals in it so it will not creat rust in your block/ rad. the n1 pump is a insurance for high rpm operation, nismo t stat and great fan are good insurance!
wabisuke1
that radiator sounds pricey who is it made by. i think i might have to change my fans i have dual i think 12in chrysler fans with one sucking air out and one blowing air in. already have new prestone 50/50 just need the thermostat and rad i have dual core out of turbo probe that i custom fitted. not having any problems now just dont want to be a third lap dop out when the time comes. thats cool i learned something new today. ill go check out redline and also check out an n1 pump.
Modified by wabisuke1 at 4:47 PM 7/5/2009
glitched
Car: 1992 240sx se
If you have pop up headlights, tests have shown that cooling panels do lower temps
wabisuke1
im looking ino those now. now that i know their purpose i begin to surmise that they would be a very good addition for high speed racing
DRFERO
i got my radiator for about 300nzd wich i guess would be around200 american dolar...i dno tho....i also raised the bonnet drift style to lower the engine bay temp and to also let the hot air out...u put longer bolts in that hold the bonet on and space the hinge from the bonet to create a gap at the back not the front...seems to work quite good
wabisuke1
i read that in the overheating rb write-up in the tech section. im gonna try that soon i just hope it doesnt disturb the aero
DRFERO
well ur not in a aero tunnel are u so i dont think raising the bonnet is gona affect ur aerodynamics
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
Don't forget a good sized oil cooler too.
wabisuke1
i was thinking more of making the car handle funny at higher speeds. seeing as when you raise the hood you kinda throw off the downward push on the front of the car. i would assume that the factoty ran it through some type of tunnel to see how the car cut through the wind
courtesy of wikipedia:Still later, wind-tunnel testing was applied to automobiles, not so much to determine aerodynamic forces per se but more to determine ways to reduce the power required to move the vehicle on roadways at a given speed. In these studies, the interaction between the road and the vehicle plays a significant role, and this interaction must be taken into consideration when interpreting the test results. In an actual situation the roadway is moving relative to the vehicle but the air is stationary relative to the roadway, but in the wind tunnel the air is moving relative to the roadway, while the roadway is stationary relative to the test vehicle. Some automotive-test wind tunnels have incorporated moving belts under the test vehicle in an effort to approximate the actual condition
im just guessing that messing with the aero on the car could throw off high speed handling as much a horrible suspension set up. not trying to be a smart a** just a piece of info for ppl out there.
240z4u
Car: '95 Nissan 240SX
It is not ideal to have the rear of the hood raised, that is a high pressure area and will allow more air into the engine bay and under the car. However if your getting hot and have no other choice...
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
Yellow4g63 wrote:Don't forget a good sized oil cooler too.
I'd say this is paramount.
maryjane
oil cooler is a must! im running a 2" koyo rad, great upgrade for track days!
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
240z4u wrote:It is not ideal to have the rear of the hood raised, that is a high pressure area and will allow more air into the engine bay and under the car. However if your getting hot and have no other choice...
+1... you'll notice your temps raise if not be higher during highway speeds (or faster salons) with the hood raised.
Carl H
another +1 for an oil cooler on an rb20...out of all the rb engines the 20 will run the hottest for whatever reason, and lots of heat can be shaved from the engine just by fitting an oil cooler.numerous threads now on how to fit a cooler using new or junkyard parts and almost EVERYONE who has fitted one has benifited greatly.
gawdzilla
Car: none
Carl H wrote:out of all the rb engines the 20 will run the hottest for whatever reason, and lots of heat can be shaved from the engine just by fitting an oil cooler.
it's probably because of the 3, the 20 didn't come with a factory cooler. the 25 and 26 has an oem oil to water cooler. also if you keep your power levels down, the motor will generate less heat.
wabisuke1
an oil cooler really never crossed my mind. i dont know why i didnt think of that before thanks.
