RB20 Questions
MidWest240Collector
I'm probably going to end up swapping an RB20DET into my S13 but I have a few questions. I know the RB25 turbo will bolt up and is good for about 300, what is a good turbo for 300+? Also what is the highest you should rev on the stock internals?
JDMEnthused
Car: Nissan 240SX
DISCO POTATO... google it man, you know.
MidWest240Collector
I'm a n00b didn't know the Disco would actually bolt up.
Wulfgang
Yeah... it won't.
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
I would say for that power range... GT3071 would be the way to go...
I've been told by the aussie guys 8250 RPM is what the 20 can rev to before upgrades are required... yet, I doubt you could make power there with the stock intake manifold without some serious pressure... but don't quote me on that
Wulfgang
8250 seems a little conservative what with redline already at 7500. What upgrades? Valve springs and balance?
MidWest240Collector
Thanks for the info guys. I expected the intake mani would have to go if I wanted some high rpms. Hopefully I'll be RB powered soon.
masticatingcow
Car: 94 Mazda FD3S
8250 RPM without upgrades. That's impressive, and I don't know if I really believe it... but I sure as hell won't call someone out on it. But if that's really the case, then, damn.
Just... damn.
Anyway, I've heard the same thing about the GT3071. If you don't mind a little lag, it's a perfect candidate.
MidWest240Collector
Not to sound too much like a n00b but the GT3071 isn't internally gated is it. And as far as turbo manifolds go, what are some good ones, all the ones I'm seeing when I search are SSAutoChrome ones or similar looking.
JDMEnthused
Car: Nissan 240SX
ah **** my bad about the disco potato.. im sure you could buy an aftermarket manifold for it but.. not sure how much that would cost.
Carl H
why would you want to go down flange size from a t3 flange to a t25?discopotato is NOT that great of a turbo, if you want 300whp from it gonna have to run 20ish psi and that isnt too good for the motor.as far as revving i have my redline set at 8.5k right now, but take it to 8 occasionaly.............
