rb20 pulls just as hard with 3/4 throttle as it does with full throttle..normal?
blues14
Car: 1995 Nissan 240SX GTS-t
my rb20 pulls just as hard with 3/4 throttle as it does with full throttle..... This is the only turbo car i have ever driven, so i dont know if this is normal. everything is basically stock.mods s14 with stock lsdintake, exhaust, no catsmall fmic 2.5 piping hot and cold sidewalbro 255 fuel pump z32 filter
is it possible i am getting too much fuel with the fuel pump causing it to run rich if i floor it?? i am still using the stock 270cc injectors and no afmarket FPR. Stock turbo at stock boost as well. any ideas or "tests" i could run would be great.
98birdls1
Car: 1998 Trans Am
Unless you've tested this on a dyno, the I'd think you just have a poor butt dyno. I'm sure its still pulling but its hard for you to tell since 3/4 is enough to spool the turbo and make you think its pulling just as hard as full throttle.
Luke
OKRB20DET
Car: 1990 S13 coupe
watch out! you might go back to the future at 88mph...
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
your running reallly really rich. how rich? 10.8 A/F. The Walbor blows past the factory FPR. You want some power back your going to have to bring that FP back to stock.
SeVa-S13
Car: '05 GTO 6spd
I had the same problem with my old 20, WOT or even above 5k rpm, the power was just flat. I just chalked it up to a dying turbo, even though it still spooled really quickly. No big boost leaks, timing was dead on, walbro, nismo fpr set right, 3" exhaust, 6-range plugs...but 3/4 throttle was still pretty damn quick.
(I sold the car before I got around to fixing it, as it just sat most of the time.)
blues14
how difficult is it to hook up a fpr?how do i get it set to where it needs to be,dyno only??
SeVa-S13
Car: '05 GTO 6spd
Really simple; goes in place of your stock one if you get the Nismo one. You'll need a fuel pressure gauge to hook up inline; set it to 43psi with vacuum disconnected and once given vacuum, it should drop to ~35psi at idle.
