Ihiryu »
https://forums.nicoclub.com/ihiryu-u35607.html
Mon Nov 05, 2012 11:42 am
Okay guys,
I just swapped in a RB20 into my S30. The car starts and runs, but has a problem with revving up. The Rev's aren't very clean, has an issue with stalling after revs too. At first didn't run well when cold.
The motor got a new gasket kit (installed by me), I've double checked mechanical timing, and everything seems good there. I've read on the forums about setting timing on the CAS, but it seems like the CAS only goes in one way, (15 degrees for a manual), so I'm not sure how I'm supposed to do that.
The only code I get is 43
I verified all the wiring for the TPS and idle switch. They all have power, ground, and signal to the ECU. So what's left is a bad TPS. I'm going to try to wire in a Z32 one in later.
I've already replaced the CTS sensor, but I haven't driven it since I replaced it. But it seems to run a lot better.
I tried to replace the CAS with one from a Z32, it physically fit, but did not fire.
Seems like the previous owner of this motor replaced the coils since they don't look broken at all (that and they are blue). Should I buy another CAS and ignitor just to try it? Forgive me, I'm a little new the RB's and I know the ignitor and coils seem to be a common issue.
