i'm having the same issue. My first 2 cylinders aren't firing.
Things i've checkedIgniter Chip - goodecu signal to ic - goodwiring to injector and coil packs. same
I physically removed my fuel rail and left the plugs in and watched them spray. Then i watched my coil packs fire with the plug installed to chasis ground.
I then thought it was a vaccum problem at the fuel rail and i pulled the plugs again and there is still no combustion.
need more info email me at
[email protected] or usmcgetsome on yahoo messenger.
