mello88 »
https://forums.nicoclub.com/mello88-u18450.html
Mon Oct 29, 2007 12:39 pm
Hello 91240sx rb20det, I sympathize with your problem... A close friend went thru similar issues with his RB, so here are some ideas for you.
First off read the FSM chapter on setting your timing, it's pretty simple if you have a timing light. You'll know when it's set right, because when the timing light flashes the bump on the lower timing cover lines up with the correct mark on the crank pulley.
Like they suggested, having a boost leak is very likely. You should consider build/buying/borrowing a boost leak tester to pressurize your hotpipe/fmic/coldpipe/intake manifolds to see where you have any leaks. Don't forget to block off your PCV when you do this otherwise it won't work how you want it to...
Running rich is probably because of two things. One, your stock FPR + Walboro is a potential problem considering the age of the FPR. Replace it eventually with a Nismo (or whatever other brand you trust) and set your fuel rail pressure to 43psi (3 bar) without the vac hose hooked up. The second thing is the stock ECU runs really rich under load anyways. What AFR do you have, from your motor (in the past) to reference to where it is now?
Check your coilpacks to make sure one of them isn't cracked and leaking spark under high load. I suggest this because of your comment about when you just crack the throttle and your motor feeling better... At WOT there is a lot more load on the coilpack vs at idle or part throttle, so sometimes the car will idle and part-throttle cruise with "full power" but whenever you step on it it'll sputter or feel like it lost power. Does your car miss occasionally at idle?
BTW your "performance shop" telling you that your ECU needs replacing is a give away that they have no clue what they're talking about... What diagnostics did they perform to arrive at that conclusion? It's not like the ECU just forgets part of it's memory... It's a lot more likely that a sensor went bad, or you have a short or something mechanical failed...
If you really wanna play around with the ecu, swap yours with a known-good one from an RB20 friend. Also check that your harness bolt (connects the harness to the ECU) is tight. Next you should unbolt it from the kick panel, flip it around and use a flatblade screwdriver to put it into diagnostic mode and read the DTC codes off of it (read the FSM for instructions on how, plus a list of code #s). DTCs are useful for finding out if you have a wiring short to one of the sensors, plus it's a quick and free diagnostic you can do any where. I'm assuming that a code 34 [for knock sensor/KS wiring] would probably put the ECU into a safe mode and retard spark timing.. Which kills your power. At least that's what happens on the KA so I assume the RB ECU handles code 34 similarly...
GL hope these suggestions help... When you find your problem pls update your thread so other ppl can learn from ur troubles!
Modified by mello88 at 3:54 PM 10/29/2007
Modified by mello88 at 3:57 PM 10/29/2007
